Build Error of the oddest kind
When I tried to build a source distribution file in a project I get the following error message.
Error copying files.
Source: Program Files:\National Instruments\LabVIEW 8.5\resource\visarc
Destination: C:\Seals Group\LabView\builds\FSFF2 DAQ LOAD_and_LEAK\My Source Distribution\visarc
Librarian Path Location.vi
The details of the error are as follows.
Error 1 occurred at AB_Destination.lvclass:Copy_File.vi -> AB_Source.lvclass:Copy_SourceItem.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_FRAMEWORK.vi -> AB_CreateNewWizard_Invoke_CORE.vi -> SDBUIP_CreateNewWizard_Invoke.vi -> SDBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
I checked the location of visarc and it is in C:\Program Files\National Instruments\LabVIEW 8.5\resource not in Program Files:\National Instruments\LabVIEW 8.5\resource\visarc.
Why is Program Files being shown essentially as a hard-drive? When I checked the VI search path it is:
Could someone please give me some guidance I have hit a brick wall?
Thank you
(3,069 Views)
Accepted by topic author NIPEN
This has come up before. Did you try a search?
(3,066 Views)
smercurio_fc
Thank you for finding the solution. It worked quite well.
(3,027 Views)
