Build XY Graph
Yes, right-click the existing y axis and select "duplicate scale", then "switch sides". Now assign the second plot to the second y-axis via the plot legend.
Message 11 of 16
(2,615 Views)
Any idea to define the area under a curve from the left to right respectively?
Message 12 of 16
(2,572 Views)
I would try to use "Numeric Integration VI". Just plug X values and dt and it will spit you area under the curve. If x-axis values (time steps) are not uniform try using "Uneven Numeric Integration VI".
This is a real life example of those integrals you learned, or didn't learn :-), in school.
Message 13 of 16
(2,563 Views)
What is the difference in the direction you go? 🙂 Does this work?
Message 14 of 16
(2,562 Views)
The answer to my own question is no it is not workign properly lol, but you get the idea. Here is one that should work, i forgot to change the dt before
Message Edited by for(imstuck) on 02-18-2009 09:13 AM
Message 15 of 16
(2,557 Views)
This looks OK. You can count how many squares you have under the curve and it is about as result shows.
Message 16 of 16
(2,554 Views)
