Build array from random temperature
So I am trying to do the following problem for a school assignment. I haven't had much experience with labview and need assistance.
The requirement for the VI is:
Create a VI that reads 20 temperature measurements using the Demo Temp.vi. With each temperature measurement bundle the time (including seconds) and date of the measurement. Include a Time Delay Express VI to slow the loop so that it executes 4 times per second.
I have attached what I have so far, any assistance would be appreciated.
Thank You.
(4,536 Views)
First, you have it for a 4 second loop time,  not a 4 times per second loop time.
It says "bundle" so that implies using a cluster.
(4,505 Views)
I think that I set up the cluster right now. I am not sure how to do the 4 times per second loop.
(4,502 Views)
Math.  4 times per second = 1/4 of a second delay.
(4,499 Views)
It would also make more sense from a data management point of view to do the Bundle inside of the loop and have the loop autoindex an array of clusters.
(4,455 Views)
