Build array with certain value using case structure
Hey Guy's
I want to iteratively fill an array of random integers between 0 and 100 in ascending order every 1 second then add a delay routine after which if no new value is displayed in the table the program displays a string indicator " elapsed time " .
Well i done the true case but i failed the rest ! 😕 can't find how to do it !
any idea !?
That's the True case:
True Case
But i don't know how to do the False Case:
False Case
Message 1 of 15
(5,625 Views)
Just wire the array through in the false case.
Message 2 of 15
(5,618 Views)
In addition To Dennis's comment:
  • your lower shift regsiter should be initialize with -inf, else you might get unexpected results on subsequent runs because the shift register will remember the last value from the previous run.
  • It is significantty more efficient to add elements to the end of an existing array. You can reverse it for display.
  • There should also be a small delay (even 0ms) when the false case executes.
  • The array indicator should be outside the case. RIght now it won't update until the first time the case is true, possibly confusing the operator (What if the case never turns true?). It is also less efficient to hide indicators and controls in innermost structures.
  • Making the 1D array vertical on the front panel makes it more compact and easier to follow.
  • Your stop button should be on the visible part of the front panel. How else do you stop the VI?
Message 3 of 15
(5,603 Views)
You aren't creating integers, you are creating an array of floating point values.  If you want an integer between 0 and 100, you should multiply the random number by 101 and round down.
What happens if your very first number is picked as 100?  There are no integers larger than that.
You said you want it to be ascending numbers, but if you are getting a larger number, you are putting it at the front of the array,  Your resulting array will be descending numbers.
Message 4 of 15
(5,593 Views)
I want it to put in the array just the number that is great than the last number and ignore the number that is less than the previous number ! how do i wire the shift register ?
Message 5 of 15
(5,572 Views)
here how i want it:
        - if the number generated is greater than the previous number, put it in the array
Message 6 of 15
(5,567 Views)
here how i want it:
        - else if the number is less than the previous number ignore it !
i want to know how to wire the shift register !
Message 7 of 15
(5,563 Views)
When you say "previous number", do you mean the last number that was put in the array or the last number that was generated?
This snippet is based on the "previous number generated".  The FALSE case just wires the array straight through.
Message 8 of 15
(5,537 Views)
It's ok it work ! but i won't to add a delay if no number is added to the array within 5second the program print time elapsed !? how to do it ?
Message 9 of 15
(5,526 Views)
I have no clue what you are asking for here.  What do you want with the 5 seconds?
Message 10 of 15
(5,505 Views)
