Build error - Cannot Open/Create/Replace AB_Cache file
Hello, I am getting an error when I try to build an executable, or even just generate the file preview. It looks like there is some application builder cache file that can either not be created or not be found. When I go to the directory where it should be, I see other files that were modified today, but not the file in the error message. This directory also has the "read only" attribute marked by a black box within a box.
I am using LV 2011 SP1 (32-bit) on Win10 64-bit.
This is the error message I get when trying to generate the preview, and I get a similar error message when trying to build the executable.
Open/Create/Replace File in NI_LVConfig.lvlib:Parse Config to Queue.vi->NI_LVConfig.lvlib:Load.vi->NI_LVConfig.lvlib:Open Config Data.vi->AB_RW_Project_Cache_Info.vi->AB_Build.lvclass:Save_Cache.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Page_Preview.vi<APPEND>
C:\Users\username\AppData\Local\Temp\AB_Cache_{EFDF26AD-2AD0-4620-86D5-40D6087192ED}.txt
Message 1 of 1
(1,344 Views)
