Build error: "path is empty or relative"
I'm writing an application that manipulates text files. Text files are output of test equipment, and the application merges separate files into a single one, following some criteria.
The point is: if I run the program from Labview, it runs with no problem. But if I try to build an application (selecting the main VI as startup VI), I get the error in the picture.
24182i21DCFC2A0B156088
I really can't figure out the meaning of this error. Main VI and sub-VIs have path-type controls, but their default values are all absolute paths (eventually c:/)
Inside main VI, I'm using a reentrant VI recursively. It's the first time I'm doing it under Labview: am I missing something about that?
My LV version is 2009.
Any help is greatly appreciated.
(3,681 Views)
...any idea?
(3,658 Views)
Hi xdaf,
I've read your message and I think that the best way to solve your issue is to reproduce the same problem. Can you upload your code?
______________________
Simone S.
Academic Field Engineer - Med Region
(3,646 Views)
Hi Simone,
Thanks for replying. I can't post the code because it contains confidential information.
Nevertheless, the problem was solved with the help of your colleagues!
In case someone is interested: under the Build specification properties, select "advanced", and activate the "Use Labview 8.x file layout".
Regards
(3,592 Views)
