Build errors with 8.5
I installed LabView 8.5 and tried to build the code, but it came out the following errors.  The code was built in 8.2 successfully.  Don't why.
Error 1 occurred at Invoke Node in AB_Source_VI.lvclass:Close_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488:  Command requires GPIB Controller to be Controller-In-Charge.
Method Name: Save:Target Instrument
(2,746 Views)
Hello Scott,
The first thing you might try is mass compiling all of your project' vi's since you're migrating your vi's from 8.2 to 8.5. This KnowledgeBase has instructions on how you can do just that.
Let's see where this gets us.
Cheers,
Emilie K. | Applications Engineering | National Instruments
(2,725 Views)
