Build errors
I had this errors:
The following product(s) are not found on the system or have been upgraded:
NI DataSocket
NI USI
In the details window:
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_PreBuild.vi >> CDK_Validate_DistParts.vi
Please help me
(2,816 Views)
Hello Zibi,
It would be a good idea to do a repair of LabVIEW. A repair will check all of the links and replace any files that are missing.  To repair go to the Control Panel and select Add/Remove Programs. Then select Software National Instruments and click change/remove. This will open a new window. In that window select LabVIEW and then choose repair.
Can you try this and let me know if you still face the same issue?
Antonios
(2,793 Views)
