Build exception error
After converting a LV7 application to a LV8 project and attempting a build, the following message appears:
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_Build.vi >> NI_MDF.lvlib:MDFBuildDist_Build.vi
Loading product deployment information
Adding files to installer
Done adding files
Preparing to build deployment
Copying products from distributions
Building deployment
Copying setup files
Setting merged database information
Setting product information
Setting developer part information
Starting final build
*** Error: Caught an exception of an unknown type. (Error code -1)
*** End Error Report
Done building deployment
Has anyone run into this before, and know how to get rid of it? Smiley Sad
Any help appreciated... Dave Gardner
(3,237 Views)
Hello Dave,
Do you have some invalid filename characters such as / \ : * ? " > < | in your executable filname, because this could cause this problem.
If your filname contains such characters please remove it and it should work!
Regards, Christian
(3,226 Views)
Christian,
No, there are no invalid filename characters in the executable filename. I ended up rebuilding another installer from scratch in order to get it to work, which suggests that the conversion process for non-LV8 applications is less than robust.
Dave
(3,211 Views)
