Build .exe problem
Here is my case:In my application,I have build my vi to .exe.But when every time I run the .exe,The program will run,it takes long time to run the program.So I want to control the program ,when I first double click it ,it don't run until I click the "Run" button.Can LabView do it.
_________________________
EZCONN TEST ENGINEER
V
(3,234 Views)
Rioght click the icon and select VI Properties > Execution and make sure that the check box "Run when opened" is unchecked.  This will make you press the run button to start the vi.
Kenny
Kenny
(3,228 Views)
I make sure the check box is right as you say,what I mean is when I open the .exe, the program is running.I don't want it run until I click the "run"button.
V
(3,222 Views)
Kenny,my problem has been solved.
Thank U.
V
(3,211 Views)
