Build .exe that contain .dll
Hello All,
I am trying to build .exe which need to use .dll.
In block diagram, I use functions strip path and build path.  Dll file is on the same location as .exe application.
Please check att.
I tried to build application by putting dll in always included, but it seams that doesn't work in that way.
Can you please advise.
Thank you.
(2,421 Views)
Accepted by topic author milan87
Look at the help for the Current VI's Path:
Note To obtain the path to the directory containing the application, use the Application Directory VI.
Me thinks you are using the wrong path.
mcduff
(2,376 Views)
Start reading here about what causes this. (... but I also recommend to place the dll into the "data" folder for consistency and adjust the path accordingly).
(2,369 Views)
