Build executable and make it constant the size of window
@tan0709 wrote:
Hey there,
Could you please help how to deal with the font size as it doesn't scale with panel. The table size is also kind of distorted.
The scaling proposed above (15 years ago) is very "limited" and suitable not for all use scenarios. In most cases of complicated UI you will get overlapped captions, etc. Better to split and cut GUI area with splitters, then adjust the rules how they needs to be scaled. Will be much better.
Message 11 of 11
(190 Views)
