Build executable with preserved hierarchy
In my application the configuration file and log file needs to be placed under C:\User\<user>\Documents\OVC_Data.
How do I build the exe to preserve the hierarchy?
In the Destinations category the Support Directory has Directory selection grayed out.
From multiple files only one file needs to be under Documents folder.
The installer needs to be created from the executable with the same hierarchy.
Thanks!!
(2,802 Views)
I recommend you to do the following:
  1. Create a build script for the application (EXE) only. Don't bother about any support files here. If the application is built on a plug-in architecture, you should include source distributions for the plug-ins in the EXE build script already or create a dedicated build script for each plug-in individually (type: source distribution).
  2. Once the build is finished (and runs on your development system), you should create a build script for the installer.
    1. Configure the destination directories for all included files. You can create new destinations by pressing the "+" symbol below the list of existing destinations. Configure appropriate folders for each destination.
    2. Distribute all files into the configured destinations as required. The build script of the EXE will include the EXE as well as some support files (e.g. ini). If you are using plugi-ins, this will also include the plug-ins which you configured in the EXE build script. If you chose to use dedicated build scripts for each plug-in, you have to include them here. Note that you can only distribute sources you have in your project. So it is required that all support files (cfg, ini, dat, ...) are part of the lvproj.
    3. Once you finished distributing your sources, chose to add additional installers (e.g. LV RTE) and finish the settings for the installer. Build it.
  3. Check your installer on a blank system. It should work. If not, identify missing components and make sure that they are distributed into the correct location.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,777 Views)
