Build fails due to NVIORef.dll
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1 occurred at ABAPI Dist Copy Non-VI Files.vi -> ABAPI Dist Build LLB Image.vi -> ABAPI Copy Files and Apply Settings.vi -> EBEP_Invoke_Build_Engine.vi -> EBUIP_Build_Invoke.vi -> EBUIP_Build_Rule_Editor.vi -> EBUIP_CreateNewWizard_Invoke.vi -> EBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  An input parameter is invalid.
NI-488:  Command requires GPIB Controller to be Controller in Charge.
What does this mean?????
(2,924 Views)
Exile,
There are a couple of things we need here to see what is going on. First, what version of the LV app builder are you using? (7.1,8.0, etc...) Second, what type of application are you trying to build, and on what OS? These are all important things. Another thing to help us try and reproduce the issue would be to create a small program that shows the same behavior. If this is not possible, then posting the code that you are having trouble with would be the next step. Let us know about these things and try to post an example. Thanks.
Tyler H.
(2,909 Views)
Tyler;
This error does not occur any longer. I am not sure why it went away...
Thanks for your response.
Exile
(2,895 Views)
