Build for PDA hangs or takes too much time for simple VIs
I am using LabView 7.1 PDA and tried to build a simple VI for testing.
The executable was built but when the dialog "Downloading..." appears then LabView hangs and I
just can close it with the taskmanager.
I have also used the Emulator for Pocket PCs and it works properly.
Can somebody help me?
(I am using a Compaq iPAQ 3760 (Pocket PC 2002),ActiveSync 3.8)
Thanks, Boro
(3,003 Views)
As far as I know, LV 7.1 should only work with PocketPC 2003 and later.
I'm not sure, but it's possible that this is your problem.
Instead of running the application, use build for PDA from the tools menu and copy the file manually into the device, and see if that works.
___________________
Try to take over the world!
(3,001 Views)
This is true. Look at here:
http://digital.ni.com/public.nsf/websearch/7D65D66EB07111F186256EBD005A5499?OpenDocument
Questions on why the Pocket PC Emulator hangs when I download my PDA application are dicussed here:
http://digital.ni.com/public.nsf/websearch/4B5A26F80E59112286256F0B00707723?OpenDocument
Kai Kratt
(2,986 Views)
Hello!
Thx for your help!!
I have already tried to use "build for PDA" and to copy the file manually to the PDA,
but it can't be executed on the PDA.
I have also tried to search for an Pocket PC 2003 Upgrade for the Compaq iPAQ 3760
but according to the HP Homepage there is only an Upgrade for the 3900 series available.
Is there any possibility to solve this problem!!!????
in desperation, Boro
(2,970 Views)
