Build pulse train using analog input as trigger
Hi all,
I would like to build a diagram to generate a pulse train with a pulse width controlled by external triggers.
I have 2 analog inputs (FLAG1 and FLAG2) which I want to use to start pulse and stop pulse respectivelly.
I want to generate a digital pulse train using these external signals as triggers, in this way:
Could anybody help me on it?
I just have the trigger signals (FLAG 1 and FLAG 2) in a virtual channels (Dev1/ai0 and Dev1/ai2 on PCI-6036E). How can I generate the resulting pulse train?
Thanks in advance.
Maria
(4,383 Views)
You can build a signal like that using Basic Functioin Generator.vi
It looks like all you need is a square wave with a different duty cycles, which that VI can do.
Richard
(4,365 Views)
Thanks for your reply.
I think this module can be used in the block diagram, but I need to trigger the pulse (start and stop) with analog inputs (Dev1/ai0 and Dev1/ai2 from PCI-6036E), this is my main problem.
(4,361 Views)
I agree with Broken Arrow.
The main problem is the hardware you wanna use the 6036E. Otherwise, the change detection polymorphism of the timing DAQmx VI would have been a good alternative if I don't misunderstand:change detection
Romain DUVAL || RF & Semiconductor Staff System Engineer || CLA || CTA
National Instruments France
(4,334 Views)
Hi Romain,
thanks for your help. I finally got this behaviour with this block diagram:
Maria
(4,322 Views)
