Build specifications
I have a problem on project menu Build specifications. The sub menu are missing from right click window as attached picture. who can I fix it?
(3,011 Views)
I recommend making sure you have LabVIEW Professional activated, or the LabVIEW Application Builder (if using LabVIEW Base or Full)
Other useful articles:
(2,984 Views)
Thank you , yes I check the lenience and its not activated.
(2,926 Views)
