Build table using report generation
I need to print a table on word report using Report generation toolkit using Labview 2011. Here I have attached sample report which I have generated and also attached project file.
In this table need to Bold Text on First column and First & second row. I made a state machine architect to initialize and build table for report generation.
I have 10 different table data need to be done as same format, but it is not repeating the same format and it is printing some time bold or some time missing some column or row  to bold the text. This is happened randomly and some times its bold all the data in the table.
Its looks strange...! Here I am using subvi's and generating same data with for loop of 10 times. Check this project you will come to know.
how to solve this... Any bugs in report generation toolkit on labview 2011?....
Balaji DP
(3,284 Views)
is this bug in report generation tookit? or MS word 2007 and 2003?
Balaji DP
(3,262 Views)
I resolved this issue.... contact me if you came accross this issue
Balaji DP
(3,241 Views)
Hi Balaji
How do you resolved the is issue that you have?
Please let me know.
Thank you for your help.
Marlin12
(3,139 Views)
