Build waveform function and usage
Hi.  I have programming that looks like the dump below.  Are there ways I can improve on this.
The Waveform function has an array for Y (implying multiple values)  while the t0 is just a single time element.  However, my data is sporatic suggesting a different non-regular time for every Y element.
My wish is to input an array for the Y's and the same size array for the t's ??
or
Am I stuck with processing every Y-t set separately ??
Regards JC.......
(2,421 Views)
Small portion of the code cannot explain what you are doing....
Share the code so that we can better understand
CLD Using LabVIEW since 2013
(2,403 Views)
@pushkin wrote: my data is sporatic suggesting a different non-regular time for every Y element.
Regards JC.......
Sounds like a X-Y chart is what you need.
=== Engineer Ambiguously ===
(2,390 Views)
RTSLVU said XY graph.
However I need to use a Chart, since the data arrives incrementally and it is substantial over time.
Regards JC......
(2,373 Views)
