Builded executable doesn't close the main VI front panel
I created an application with the Application Builder. All of it runs well, except that when the operator ends the program, the front panel of the main vi (the only top-level VI) remains open.
Moreover, inside the VI window appears the toolbar with only the Run button on (in the VI properties I choosed to hide toolbar and menu bar).
Is there a way to close the front panel when the program completes execution?
Roberto
(2,806 Views)
I ussually use the "Quit LabVIEW" function found in the application control palette when application finishes. I use a utility that checks to see if it is running in the development or run time enviroment and only quits LabVIEW if it's in the run time enviroment.
This wouldn't work to well if you were running other LabVIEW programs though.
Brian
(2,806 Views)
