Builder doesn't seem to work?
I've a big application and now i want to build it, when i have all the settings filled in, i push build, in the taskmanager i see the memory labview is using rise to 1,6 Gb then boom, the build status says it's done but when i push "explore" i'm directed to an emty folder and when i click "done" my project hangs...?
what is wrong? i include an ini file, but that wouldn't cause this?
Thijs
Message 1 of 11
(3,255 Views)
Impossible to say without seeing at least a bit of your code -- or failing that, how about some information like what version of LV? What OS? What drivers are you using? Have you been able to build other applications? Have you been able to ever build this application?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 11
(3,251 Views)
Thanks for your quick response:
Labview version 2013 latest patch
Platform windows 7 latest updates
I also use nidaqmx 9.8
I have build a working exe before (but this was 2 weeks ago) and i have added some sub vi's
And this is exactly what happens:
I push the build button and it says initializing... and then after a certain time the done button and the explore button lights up. And the whole thing hangs...
I have alot of code, somewhere around 200 vi's
Thijs
Message 3 of 11
(3,241 Views)
So the only external drivers of any sort is DAQmx?
Do you still have an archive of the project before the changes that you can try building?
If you build a small application that just does something simple like return a random number, does that work?
Have you added or changed anything on the computer in the last two weeks?
Mike...
LabVIEW Champion
Message 4 of 11
(3,237 Views)
I'll have to check this monday...
I have done a whole new install of labview recently. But that shouldn't cause this...?
I'll try to make a simple exe coming monday.
Thijs
Message 5 of 11
(3,229 Views)
If something went wrong during the install, you bet your life it could cause this!
Mike...
LabVIEW Champion
Message 6 of 11
(3,224 Views)
I tried it on another PC with another install of Labview, same problem... I also tried to make a small program where a for loop fills an array. Then when i make an executable out of it it works great.
I really don't have clue? Is there a sub VI limit? I use around 130 sub VI's in my application and when it loads the first time the number of vi's loaded are around 500...
Thijs
Message 7 of 11
(3,171 Views)
No, there is no VI limit.
MIke...
LabVIEW Champion
Message 8 of 11
(3,152 Views)
After several updates for windows 7 it just works?? I realy don't understand...
Thijs
Message 9 of 11
(3,134 Views)
Again, if windows was badly out of date there could be a piece missing that the builder needed when creating larger applications. But hey, you can't argue with success.
Mike...
LabVIEW Champion
Message 10 of 11
(3,120 Views)
