Building Applications
I am a bit confused as to which files i should include when building a
Labview application.
I have a top level VI which is made up of sub-VI's which include VISA and
HTTP blocks.
When i build my application i include the top level VI, the HTTP Server VI
(from http0.llb)
as a dynamic VI, and a .zip file which has the internet directory as a
support file.
Is this all i need to include? I hope not as my application doesn't work in
its present build state!
The application loads and the HTTP Server starts but he Server is behaving
oddly! and Internet explorer
can't find the server.
Help!!!
Matt
(3,075 Views)
I cannot give you a full answer to your question, but I know that you must at least include any files that are called dynamically (i.e. call-by-reference). You do not need to include explicit subVIs and functions. If that does not help, please include an example VI to make it easier to understand the problem.
Martin
(3,075 Views)
You need to ensure that NI-VISA is installed on any machine that runs the executable.
Brian
(3,075 Views)
