Building DLLs from VIs with array as output
Is there any special way to build DLLs from VIs having arrays as outputs. Suppose I have a VI "Random" with input "nrand" and output an array "the_random2". When I build DLL from the VI, I have something like this in my header file
void __stdcall Random(long nrand, double the_random2[]);
Now it returns void. So I have to pass the array as pointer and retrieve it. If I use Mathscript to load the DLL and call this function, how do I pass the pointer to the array "the_random2"? Simply speaking, any useful method to build DLLs with array outputs and the right way to call them from Mathscript would be appreciated.
Regards
NRK
(2,854 Views)
Mathscript can call shared libraries such as DLLs, however make sure that they are compliant with the supported data types.  Note that these functions are not supported with the base package.  The details of the sytax of each function is described in their specific help page.
Hope this helps!
Nadim
Applications Engineering
(2,828 Views)
