Building EXEs and Installers from command line
Is there a way to build an EXE and installer (via Application Builder) through the command line? It looks like it is possible, but I haven't been able to find the commands to accomplish this. We will be adding some .NET components to our LabView application, and I'd like to be able to: - Compile .NET code - Execute Unit tests - Compile LV code (using new .NET assemblies) - Package LV application I know I can control all of this through a VI, but I'd rather not maintain my build process in LabView.
(4,219 Views)
There is an example that ships with labVIEw. here is the path
C:\Program Files\National Instruments\LabVIEW 2010\examples\project\programmatically build\Build Targets via Command Line.vi
Guru
Regards
Guru (CLA)
(4,210 Views)
I don't have that example installed, but it looks like the best solution is to build an executable that wraps BuildTargetBuildSpecification.
(4,166 Views)
Alex,
This KB has some info on this, let me know if it helps!
http://ae.natinst.com/public.nsf/web/searchinternal/0413bd4f4bff32f086256e4a007c7a60
Jon
(4,146 Views)
Is that an internal resource?  I'm not able to reach that address (DNS can't resolve it).
(4,141 Views)
Sorry about the broken link.  Here is the correct one:
http://digital.ni.com/public.nsf/allkb/0413BD4F4BFF32F086256E4A007C7A60?OpenDocument
(4,126 Views)
