Building Installer Crashes Developement System LV2014SP1
I understand that this is an old thread, but I have a possible solution to the problem of the TSVN Tool Kit vs LabVIEW.
First, my problem: I was always getting the exact same error realated to the tool kit when I closed out LabVIEW.  Almost every single time.  What solved my issue was to go to close the project (saving any files that need saving) but NOT close LabVIEW.  Then re-open the project from the Startup Screen.  This causes all the overlays to be refreshed, and now I can close LabVIEW without a crash on exit.  It seems that the tool kit freaks out if you exit LabVIEW before it has a chance to update the overlays.
I was hoping that maybe if you did this right before buiding an install, you could solve the issue without having to remove the tool kit.
Bill
CLD
(Mid-Level minion.)
Message 11 of 13
(1,303 Views)
Sorry, the real solution is to disable the Icon Overlays --> Autorefresh in the tool kit settings before doing whatever it is that crashes the tool kit.  Tools --> Viewpoint TSVN Toolkit --> Settings --> Icon Overlays.
If I do this before exiting LabVIEW, for example, it doesn't crash the tool kit.  I presume the toolkit hates exiting when it is in the middle of refreshing the icons.
Bill
CLD
(Mid-Level minion.)
Message 12 of 13
(1,289 Views)
I've been having the same problems in LV 2015 SP1 ever since I installed TSVN Toolkit, though I hadn't put it together until reading this. Error on exit and I was able to compile my .exe-s but the installer builder would always crash. Thanks for the help!
Message 13 of 13
(1,012 Views)
