Building Linux shared object (so)
Does anyone have experience building a linux .so from a VI?
I've made a simple VI and was able to build it into a shared object (so)
using the App Builder. But when trying to link to that shared object
with a test C program, I get unresolved references:
libdouble.so is the .so I built from my VI:
../libdouble.so : unresolved reference to 'ReleaseEPDS'
../libdouble.so : unresolved reference to 'CallVIFromDll'
../libdouble.so : unresolved reference to 'InitLVClient'
../libdouble.so : unresolved reference to 'UninitLVClient'
../libdouble.so : unresolved reference to 'ReserveEPDS'
../libdouble.so : unresolved reference to 'GetSharedLibPath'
../libdouble.so : unresolved reference to 'WaitLVClientReady'
It seems like I need to link in anot
her Labview library but I don't know
which one or where it is located.
Any help? NI guys?
-Stephen
(3,103 Views)
Hi Stephen,
You'll need to link against the LabVIEW run-time engine. It's called "liblvrt.so" and is usually found in /usr/local/lib.
Thanks for pointing this out!
(3,103 Views)
