Building Several Waveforms with a single action
Hi everyone,
I have 16 arrays which I want to build into waveforms with same sampling time.
Is there a way to manage it with one action or a block, besides doing it seperately? If it is possible, how can I do that?
OZGUR
(2,745 Views)
Do it for one array. Then build all 16 arrays to a an array (it will be 2-D array now), then create a for loop, index each element and then implement that code that you created for that one array.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,739 Views)
I've found "Copy Waveform dt" block, i guess it does exactly what i wanted, i merged the signals and used that block and splitted it later. It seems working properly.
Thanks for your reply,
ozgur
(2,737 Views)
