Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Building a Toolkit
Building a Toolkit
keeperC
Member
08-12-2008
05:19 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Does LabVIEW allow programmer to build a toolkit of their own?
For example, creating a palette that has the subVIs that I created.
Thanks in Advance
Keeper
0
Kudos
Message
1
of 3
(3,450 Views)
Reply
Re: Building a Toolkit
MikeS81
Proven Zealot
08-12-2008
05:41 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi keeper,
yes it´s possible. To start you can copy all your vi´s into the userlib folder in your labview folder. If you do it, you can see your vi´s in in LabView in the user vi´s.
Hope it helps.
Mike
0
Kudos
Message
2
of 3
(3,446 Views)
Reply
Wiebe@CARYA
Active Participant
08-12-2008
06:10 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Sure.
In the tools menu, select advanced, and then edit palette. Add any
directory, library or menu you like.
Wiebe.
Tags:
Toolkit
View All (1)
0
Kudos
Message
3
of 3
(3,439 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
