Building a multi instrument modular program
I have many instruments that have their own vi. The vi itself runs in a loop, does things continuously and has buttons etc. They are essentially state machines.
I want to make a main vi that talks to these vi, tell them do something, and sometimes wait and get their return values. I would like to not mess around with the instrument vi whenever a new main vi is built around them.
What is the best way of doing this please?
thanks!
(1,066 Views)
Hi niforlinuc,
You want to change the behaviour of those subVIs, but you don't want to change those subVIs?
Seems like a tough challenge to me…
The "device driver" functions (aka VIs) should not contain a loop and no UI with "buttons etc.". The UI to interact with the device will be YOUR main VI as you call the driver functions as needed…
(1,025 Views)
