Building a simple Modbus RTU
Hey everyone.
Got a task i need to do but got absolutely 0 previous experience with LabVIEW and just struggling with it. I laid out exactly what needs to be done below. Maybe somebody with more experience could help. Thanks a lot!
*Background: Trying to run 2 VFDs using myRIO which communicate through Modbus RTU to RS-485
Simple Interface:
-When start button is clicked, both VFDs are ran, both stop when same button is clicked again. (Register 1) for both vfds
-A speed dial would have -500 to +500 which would control the speed. (Register 2) for both vfds however VFD 2 would run at 2% of the speed (speed/50)
-so ideally just start/stop button and a dial of some sort
Every time myRIO sensor is triggered on connector C (DIO1/pin12 and DIO3/pin14) VFD 2 would start spinning the opposite direction. (slave 2, register 2)
Common params im using:
-Connection Type: Serial
-Com port: COM3
-Stop Bits: 1
-Parity: None
-Mode: RTU
-Baud Rate: 115200
-Flow Control: None
Optional/Idk if needed but ideally there.
-Poll Period: 100ms
-Timeout 300ms
-Retries 1
------------------unique params to each slave-----------------------
Slave Address:1
Reg 1 = 1 (Starts)
Reg 1 = 0 (Stops)
Reg 2 = -500/500 (Speed controls, negative is reverse)
Slave address: 2
Reg 1 = 1 (starts)(but copy slave 1)
Reg 1 = 0 (stops)(but once again copy slave 1)
Reg 2 = (Copy slave 1)/50   i.e. 2% speed
Included the manuals just incase.
myRIO Manual: https://www.ni.com/docs/en-US/bundle/myrio-1900-getting-started/resource/376047d.pdf
VFD 1 Manual: https://hiflex.nl/downloads/docu/inv_freq/Application_Note_Optidrive_P2_Modbus_register_map.pdf
VFD 2 Manual: https://hiflex.nl/downloads/docu/inv_freq/Application_Note_Optidrive_E3_Modbus_register_map.pdf
274682618_656576832305893_8284065906255739278_n.jpg274682618_656576832305893_8284065906255739278_n.jpg
Message 1 of 1
(1,603 Views)
