Building an EXE using the Report Generation Toolkit (Excel)
Hi James,
I understood that you replied to "thanks bro ...". I agree that sounds a little bit rude (so no harm done that you replied and no need to excuse - at least not to me), but as I wrote, I got a kudo and and a marked solution so I am willing to believe that my answer has been helpful anyways.
Regards, Jens
Kudos are welcome...
Message 11 of 12
(1,107 Views)
The error code is the same if the template cannot be found, the classes are not included in the project or there are errors in the code when generating the report. And I tested the code without compiling and it worked, I didn't think the error was because of not finding the template.
Message 12 of 12
(1,104 Views)
