Building an application using LV 7.1
Hi folks
I've created a application using the "3D Surface Graph" only.   I used the application builder to create the exe file and the installer.
But when i tried to install this application in other pc,  the graphic does not appeared and a msg like this was displayed "Error loading control"
      I think that the script of my building file is wrong.   How can i fix this problem?
      Thanks to everybody.
(3,147 Views)
You need to include the cw3dgraph.ocx file that lives in the system32 folder. This is install as part of your Labview installation.
Regards
Ray Farmer
Regards
Ray Farmer
(3,124 Views)
Thanks Ray
The cwgraph3d must be included as a suport file in the builder and that's all?
I don't have to register this .ocx file in the windows (XP) register of the host machine?
                       Thanks for your help.
(3,107 Views)
