Building an array from values in two structures.........
I am working on an application that loads one of several VIs into the subpanel control on the main window. Each VI displays a certain part of the main system
The user  types the name of the VI and by presses return or enter(Num Pad) key . Any VI that is loaded has its ID saved in an array. This to allow
the user to move back and forth through displays loaded so far in a session. By using shift registers the array builds fine.
 Some of the newer VIs have butons that open a detailed diagram etc for a particular component. This is straightforward using an even structure however the
IDs of these 'subdiagrams' loaded through a mouse event also need to be saved in the same array. Essentially I am trying to combine VI   IDs from a case structure (key press) and an event structure handling mouse events.
Any suggestions would be welcome
(2,715 Views)
Store your vi names in a Action Engine
Ben's famous Action Engine Nugget is always a good read. http://forums.ni.com/t5/LabVIEW/Community-Nugget-4-08-2007-Action-Engines/m-p/503801
(2,700 Views)
