Building an array
I am trying to create an array of samples from my FP-AI-110,  I seem to be replacing the first element of the array each time when what i want is to create a new element for each sample.  I am inside a while loop and the reason i need the array build is so that i can create a waveform of my readings.
I should attach my vi so that it can be analysed.
I am using Lab View 6.1 and I am a student using it for the first time so please excuse the simple questions.
Thank you,
Laura
(3,314 Views)
Hi Laura,
You do not need that while loop to build array.
Do as shown in the PIC attached, to build array out of the two elements and save it to file. ( look at comments in red)
also use 'chart' instead of graph to display.
Any doubts do get back
regards
Dev
(3,305 Views)
Thank you so much for that, the only thing i am unsure of is how to make t0 (in the build waveform vi) a different sink type (it is currently a dbl)
thank you, laura
(3,292 Views)
I've worked it out!  Thank you so much for your quick response, that was so kind.. I am very grateful because now my project is coming along nicely.  Thanks again.  Laura
(3,288 Views)
Glad to have been of assistance Laura.
All the best
Regards
Dev
(3,260 Views)
