Showing results forĀ
Search instead forĀ
Did you mean:Ā
Building an executable: Getting an error message 'Not Enough memory to complete this operation'
I am trying to build executable file from my project, It is have around 1000 number of VI files. During build, In compile time i am getting error message 'Not Enough memory to complete this operation'. I am using LabVIEW version 2013Sp1.
I tried to Clear Compiled Object Cache option which is present in the Tools->Advanced. Still the same error is coming while building Exe.
Could someone help me to solve this problem please?
Thank You
(2,008 Views)
Have you checked if the destination folder has enough space ?
1000VIs or more should not be an issue.
(1,982 Views)
Sir, Destination folder has 40 GB free space memory.
Some times I am getting this error in processing time only, some times in compile time .
(1,959 Views)
Where are you building to ?
A network drive?
(1,953 Views)
Sir, It is an automatic test equipment which is having PXI Chassis with NI modules. I am trying to create executable file in the same system.
(1,926 Views)
