Building an installer in LabVIEW
I tried building an installer for an application I have created in LabVIEW. I have used IMAQ in my application. When I built the installer, under "Additional Installers"I selected IMAQ. However, when I installed the installer setup and tried to run the executable application on a computer that did not have LabVIEW, the application could not be loaded as the error message was showing indicating that IMAQ VIs are missing. Kindly advice on how to fix this problem. Are there any specific installers to be checked for IMAQ when creating the installer?
Thank you
(3,233 Views)
Did you select the run time engine for LabVIEW?
Kudos and Accepted as Solution are welcome!
(3,226 Views)
Yes. I selected the run time engine and the IMAQ installers.
(3,204 Views)
