Building and Distributing applications
I have created an exe and an installer and placed them on a network drive.  Then I went and installed the exe on different pcs.  Now I need to make changes to my original program.  So I am guessing I will need to go and uninstall my current version on each pc then install the new version.
My question:  Is there an easier way?  Can I overwrite the older version and not have to uninstall it?
Brian
Brian
(2,574 Views)
If you have just made some tweaks to the program, and not changed any of the add-ons, like a new version of DAQ-mx or LV 8 runtime over LV 7.1 runtime, you should be able to just replace the .exe and the associated files that are built when you build the .exe.
I have done this for numerous applications that we have, that way you dont ahve to uninstall and reinstall.
Kenny
Kenny
(2,571 Views)
