Building and Installing
I want to produce a stand-alone application for a VI which uses NI Labview2010 as well as the Report Generation Toolkit for MS Office.
Q: Are the support files for the Toolkit included when I build the application as well as the installer?
(3,077 Views)
There are some issues experience by many users (including me) when they try to make an executable that uses "Report Generation Toolkit" ...!!
You may want to check these:
1. Error 7 When Running an Application Using VIs from Report Generation Toolkit for MS Office
2. Including Report Generation VIs in Stand-Alone Applications (Report Generation Toolkit)
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,073 Views)
I installed the application software yesterday ... everything worked perfectly !
The Installer must have included an installer for the Report Generation Toolkit (MS Office).
I wrote the application.exe using Labview 2010 and the Report Generation Toolkit (MS Office). My operating system is Wndows 7 and MS Office 2002.
- The amazing thing is that the target operating System is Windows 7 with MS Office 2010.
I found the document: NI-Tutorial-3303-en  to be very helpful.
Thanks for your assistance.
(3,040 Views)
