Building application using DLLs
Sir,
I need to build an application. For that I have all my VIs inside one LabVIEW Library file (.llb file) including one top-level VI. I also have a set of DLLs used by the VIs in the same directory where my .llb file is located. Now I need to build an application (without creating an installer) for my program. Should I need to include the DLLs while building my application? If yes, how to do it?
Kindly clarify me regarding this.
Ramkumar. D
QuEST, INDIA.
Ramkumar.D
QuEST, INDIA.
(2,928 Views)
If you are using own DLLs, then you should add those DLLs as Support files in the application settings in the application builder. If the DLLs are from the LabVIEW VIs, then is done automatically (with some exception by drivers)
Here a tutorial with some explanation how to create an application and which files are needed:
[broken link removed]
Regards
Ken
(2,923 Views)
Hi Ken,
Thanks for your help. The link was very useful.
regards,
Ramkumar. D
Ramkumar.D
QuEST, INDIA.
(2,920 Views)
