Building application with microsoft agent
Can someone clarify if there is anything different that needs to be done while building a stand-alone application that includes VIs that use the MS agent voice VIs (for example MSagentTTS.llb) along with CGI VIs? I have been able to build applications with only CGI VIs but failed while adding MS agent VI functionality. Any help is greatly appreciated.
-Sheela
(3,705 Views)
"Belur" wrote in message
news:50650000000800000017690000-1031838699000@exchange.ni.com...
> appreciated.
You'll need to install the Microsoft Agent parts on the target computer.
They are:
MSAgent.exe - the core components
actcnc.exe - MS Speech Recognition Engine
tv_enua.exe - MS Text To Speech engine
Merlin.exe - or any of the available different voices
Theses are available for downl
oad from
http://www.microsoft.com/msagent/downloads.htm
(3,705 Views)
Thanks for your response. But I am just testing it on on my development system itself, without launching LabVIEW, on which these parts are already there and the VI itself works but not the stand-alone application built using the application builder.
(3,705 Views)
news:506500000005000000E2B80000-1031838699000@exchange.ni.com...
You may have a "strip path" problem in your EXE and LV Agent is not finding
the path to the .acs file where the Character is loaded. Install a path
indicator in your EXE on the front panel and see if your built app is
finding the correct path to ..\LV61.acs (or what ever Character you are
using)
(3,705 Views)
