Building array of clusters of 1D array slows down after each call
Hi all,
I had a problem for which I found a workaround, but I would like to understand why this is happening.
Consider the code snippet below.
I am binning a 2D array into a 1D array by transforming the 2D coordinates in order to get the average value and standard deviation of each bin. Because the number of elements is not the same for each bin I used a Build Array and stored this in an array of clusters.
This might not be elegant from a memory management pov but it performs well enough on the first run, a few hundred milliseconds. However each call takes significantly longer than the previous. The 2D array size is typically around 600 x 300 elements and the binned array size around a few thousand elements. After a few calls it can take over 10 seconds to execute, both in developer mode as in runtime environment. There does not appear to be a memory leak.
By using Request Deallocation the execution time stays more or less constant. It seems the initialization of the 1D array of clusters does not result in the same state as during the first call.
Is this a case of the LabVIEW compiler failing to outsmart the user? Am I making things worse by using the In Place Element Structure?
Message 1 of 15
(5,919 Views)
Hi Ramon,
can you provide the code from that image as a VI/snippet, together with some typical input data?
Which LabVIEW version do you use?
Message 2 of 15
(5,914 Views)
Hi Gerd,
It seems I underestimated the sizes.
See attached VI with typical values.
Message 3 of 15
(5,889 Views)
Since you're adding at the beginning of the Array it'll need to reallocate and copy the Array each time.
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 15
(5,885 Views)
I tried adding at the end but that also does not seem to help for next calls.
Without deallocation:
With deallocation:
Message 5 of 15
(5,880 Views)
Accepted by topic author RamonG
Hi Ramon,
right-click the IPE and select "Remove IPE…", then save the VI.
This cuts down the loop times from ~800ms…3800ms (start to 5th iteration) down to ~400ms (for all iterations)! (LV2020, 32bit on Win8.1-64bit)
(Prepending or appending the new element to the inner array doesn't make a notable difference.)
Message 6 of 15
(5,879 Views)
@GerdW wrote:
Hi Ramon,
That did the trick.
I guess it was a case of me failing to outsmart the LabVIEW compiler 😛
Message 7 of 15
(5,867 Views)
Hi Ramon,
when the IPE was new it helped the compiler to get smarter.
Nowadays the IPE most often is not needed anymore because the compiler is smart enough to recognize the typical use patterns…
Message 8 of 15
(5,855 Views)
Hi GerdW,
How can I remove the IPE in LV2017?
Message 9 of 15
(5,529 Views)
Hi Harvey,
read message #6
Why don't you attach your VI?
Message 10 of 15
(5,527 Views)
