Building on existing data while recording new data
I'm currently working on a program that collect samples in cycles defined before a while loop. The problem is that data collected within a cycle is wiped before a new cycle begins, but only if more than one cycle needs to take place in a single run. I've attached a handful of files below to better display the problem. I attempted to fix this problem by splitting the array of waveforms, appending each component, and bundling them back together. The only reason why this doesn't work is because the program can't collect samples fast enough. How can I rectify this?
(2,667 Views)
Accepted by topic author mecheng86
Your Record Data code won't execute until the While Loop stops.  You need to have your logging function inside the While Loop.
Have a look at the Log Data example in the Example Finder, or search for DAQmx with data logging.
A little more advanced topic that you might want to look for is Circular Buffer.
Patrick Allen: FunctionalityUnlimited.ca
(2,655 Views)
