Building waveforms for creating WAV files and Playback issues
Hi All,
I am doing some experiments with LabVIEW with the transposition of different data into audio format (It is something I have wanted to try for a while).
All of the read VIs are working perfectly it is just the synthesis of the waveforms that I am having trouble with.
I have reduced my code down to a basic function generator and for loop that runs 100 times, I am then outputting to an existing WAV file to be overwritten.
All of this code runs fine and it is definitely saving something to the WAV file, but I cannot play it in windows media player (it gives me a generic error message).
I am not sure what the problem is as it all runs fine in LV, I have attached my code.
Can anyone deduce why I cannot play my output in WMP?
Also the waveform structure is new to me, can anyone tell me how to compile a waveform manually I cannot find anything online?
Thank you very much.
(3,191 Views)
Everything you need to know about a waveform data type is in the help. It's really simple as you can see from the create waveform function. It has a start time, a dt or the time between samples, and the y array. You can create/modify the y array just like any other array.
(3,187 Views)
