Buils
Hi
I have working program in develope mode, but when I tried to build an application I got this message when the builder is saving after compiling:
An error occurred while saving the following file:
N:\dev\TAX3\TEST\SYSTEM\sw\main\utils\tax3_sub_test_caller.vi
Details:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem.
Use the following information as a reference:
Close_Reference.vi -> AB_Build.lvclass:Save.vi ->
AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi ->
 AB_EXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi ->
 AB_EXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi ->
AB_UI_Frmwk_Build.lvclass:Build.vi -> AB_UI_FRAMEWORK.vi ->
AB_CreateNewWizard_Invoke_CORE.vi ->
EBUIP_CreateNewWizard_Invoke.vi -> EBUIP_CreateNewWizard_Invoke.vi.ProxyCalle
Possible reason(s):
LabVIEW:  Cannot save a bad VI without its block diagram.
______________
The tax3_sub_test_caller.vi is running perfect and have a block diagram.
I am using labVIEW2010-2 and windows XP
Niels Krabbe/Frogne A/S Denmark
Message 1 of 1
(2,429 Views)
