Built Application containing VISA resource name control in Labview 7.1 not working
Very new to Labview (student). I built an application (my first)that uses VISA serial in Labview 7.1. The application contains a VISA resource name control. The program worked when silmulated, but not when built as app. When I removed this control from the application and made it a constant - the app worked. Any reason for this? A way around it perhaps? Would love an answer. I did make sure the Run-time engin is correctly installed and that it is not the problem. Thanks, Madri
(2,849 Views)
You need to install visa runtime engine on the machine where your exe is installed
Doc-Doc
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(2,849 Views)
I built and tested the exe on the same PC (mine). The exe (without the VISA resource control) is now installed on a different PC (with run time engine) and all is fine, but I would like to have that control in the app. Any ideas? Thanks for the help, Madri
(2,849 Views)
Hello �
Take a look at the following link. I think you will find it useful.
My VISA Executable Does Not Run on a Non-Development Machine
Hope this helps!
S Vences
(2,849 Views)
