Built-in Mouse Wheel support for Numeric/Ring/Enum malfunction ?
When Numeric/Ring/Enum ctrl wired to connection pane, it's built-in mouse wheel function got disabled.  Still trigger mouse wheel event, just doesn't change value.  Is this by design?
LabVIEW 2019 SP1
Windows 7 Pro
George Zou
(3,941 Views)
When I move the mouse wheel with a Control selected, in Windows 10, this moves the Control up and down on the pane.  I've never noticed that it changed the value (in LabVIEW), but maybe I'm not "doing it right".  However, if you can detect mouse-wheel movement, what is to stop you from trapping the Event and using it to change the Control's value up or down?  (My apologies if I've totally "missed the boat" on your question).
Bob Schor
(3,876 Views)
If you take a look my VI, you won't ask this question.
But it suppose to be a built-in feature, I don't see a good why it should be disabled when the ctrl wired to connection pane.
George Zou
(3,871 Views)
Hi George,
I don't have an answer, but I see the same thing you saw and I agree it's weird.
That being said, I didn't previously know you could scroll on Ring controls without opening the dropdown...
GCentral
(3,867 Views)
By default, Built-In Mouse Wheel Support is set On Key Focus.
If you change it to On Hover, mouse wheel works even if the VI is not running.
Works great if you know the items and order, such as Monday, Tuesday, ...
George Zou
(3,856 Views)
The increment\decrement key bindings also stop working when connected to the CP.
The focus key binding does work... The toggle (for Booleans) also work regardless a CP connection.
(3,845 Views)
The mouse-wheel functionality for controls on the connector pane has been fixed in LabVIEW 2021. I apologize that I missed including this in the list of fixed bugs when LabVIEW 2021 released.
Christina Rogers
Principal Product Owner, LabVIEW R&D
(2,708 Views)
