Built is not executing in Runtime
i have to PCs. One with LV 2013 to develop and create exe-files and a second PC with only Runtime installed.
Just now i tried the first time to execute a fresh built exe-file and got this popup:
But in my Windows 7 64bit under software i see that it is installed:
What is the problem?
I installed "LVRTE2013_64bitstd.exe" or is this the wrong runtime as my Labview-version is LabVIEW 2013 SP1 (32-bit)
Thanks for help
(3,094 Views)
Accepted by topic author OnlyOne
Solved:
Executables built with LabVIEW 2013 or 2013 SP1 (32-bit) require the LabVIEW 2013 (32-bit) Run-Time Engine.
(3,088 Views)
Thanks for help
Indeed, if you built an EXE with a 32bit version of LabVIEW then on the taret PC you need to install the 32bit RTE.
To avoid this kind of trouble, after building your EXE you can build an install for it, doing this, LabVIEW will let you include the appropriate RTE in your install.
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,086 Views)
All that said, the error message in the first picture should mention the word "32bit" to avoid confusions like this!
Why doesn't it??? 😮
(3,048 Views)
