Bundle block strange beaviour, maybe a bug ?
I  get a strange behaviour with the example vi attached
I have the following data structure :
a cluster made of 1 boolean and a fixed lenght array of 4 elements.
Each element of the array is a clusters made of two numeric values (N1 and N2)
I want to reset the values of N1 and N2 of some indexes of the array pressing a button.
In the example the value N1 and N2 are initialized at 1.
Pressing the reset button I would like to set the corresponding index value of N1 and N2 to 0.
To see the current value of the array I created an indicator.
In the example you can find two similar sections in the diagram.
The only difference is the connection point fo the 'Array Indicator'.
If I attach the indicator to a 'private' unbundle block I get the behaviour I expect: the values of N1 and N2 are set to zero.
If I attach the indicator to a node like in the lower diagram section I get a strange behaviour: the Status Out 2 is never updated. It seems like something don't work in the bundle block.
Another thing I've seen is that if I remove the boolean from the big cluster everything works fine in both cases.
I tried this example with LV 6.0 on two machines with Win XP and 98 .
Any idea ? Can somebody reproduce this behaviour also on LV newer versions?
thank you
Gianpiero
Message 1 of 9
(3,811 Views)
Hi
I use LV7.0 on Win XP Professional. I just ran your vi and there were no differences.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 9
(3,802 Views)
Should your array of boolean buttons (reset) be empty (greyed).
If you set the array to have the four boolean, then everything is fine.
Regards
Ray Farmer
Regards
Ray Farmer
Message 3 of 9
(3,804 Views)
Yes, that's right. I noticed that too, but did not think about mentioning it ;).
Using LV8.0
Message 4 of 9
(3,796 Views)
I set the array of boolean (reset buttons) default value to 4 elements (vi attached)
But nothing changes for me. I still get the same problem.
Which LV version did you use to try the vi ?
thank you
gianpiero
Message 5 of 9
(3,794 Views)
Yes, your reset buttons were "greyed" because their containg arrays were "not initialized" - the solution there, is either to set some default values and "Make the Current Value Default" and save, or maybe it would be better to use a cluster of booleans and use the "cluster to array" function on the block diagram.
I've tried your example program using LV version 7.0, and I can't see any problems at all - the lower loop's output has exactly the same behaviour as the top loop.
Mark.
Message 6 of 9
(3,781 Views)
LV version 6.1 is the oldest version I have installed - I don't see any odd behaviour there either.
Looking at the diagram/wiring, it's very difficult to understand how such behaviour might be possible - unless it really is a bug, but it seems so unlikely because it would be so fundamental.
Message 7 of 9
(3,766 Views)
In the last example I post, the array of buttons was initialized but the problem is not there.
I tried also using a cluster to array, (attached vi) but nothing changes: the upper loop reset the lower doesn't.
And moreover connencting an indicator should not change in any way the data flow.
Probably is something related to LV 6.0 .
Anyway, I can do like in the upper loop to avoid the problem.
thank you all for your help!
gianpiero
Message 8 of 9
(3,767 Views)
I was using 7.1
Have you checked the Knowledgebase, seems to remember something about clusters that the later versions fixed.
Regards
Ray Farmer
Regards
Ray Farmer
Message 9 of 9
(3,755 Views)
