Busy Waiting While Loop in SubVI?
I'm working with a motor drive that sets a busy waiting flag while an instruction is executing and clears the flag when an instruction has been completed. I need to poll the busy flag, so I was planning on creating a subVI that contains a while loop to poll the flag. But, I know that it is recommended that while loops should not be placed in subVIs. I was wondering if there's an alternative. Would it be ok to put my code in a subVI? I've posted the code as an attachment.
Thank You,
Molana
Message Edited by Molana on 08-21-2006 02:18 PM
Message 1 of 8
(4,631 Views)
Nothing wrong with the way you are solving the problem or using a While Loop in a Sub-VI.  Just be sure to add a small delay like 20 milliseconds to prevent the loop from taking too much CPU.  While loops and Sub-VIs are fine.  Another tip maybe to add a timeout condition to the while loop.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
Message 2 of 8
(4,623 Views)
It is fine to put while loops in subvi's (in my opinion), as long as you can terminate it from the calling vi, either programmatically, or manually, and preferably both.
Use a queue or LV2 style global to pass a possible "abort" or "stop" button on the front panel of the calling vi, so that the subvi can be stopped for whatever reason.  References will also work, but have more overhead.
Message 3 of 8
(4,618 Views)
I don't see any "flag" in your code. Is this just a boolean indicator on the calling VI that is lit while the subVI executes and reset once the call completes? Are you just setting the "busy" cursor?
You should make sure to place this in a paralell loop in the main VI so you're not blocking the UI code and other processes. Also, as others have mentioned, your while loop needs a small wait.
Message 4 of 8
(4,617 Views)
Would a semaphore work?
Lynn
Message 5 of 8
(4,606 Views)
Well, the flag is ouputed through the "CR detect" Subvi. The string output of CR detect will either be 'B' for busy or 'R' for ready. The while loop will execute as long as the string output is 'B'.
Message 6 of 8
(4,590 Views)
I'm not sure how to use a semaphore in this case.
Message 7 of 8
(4,587 Views)
Molana,
I don't think a semaphore is what you are looking for.  You could possibly use an occurrance or a notifier though.  An occurrance will let you "wake up" your main thread when your subvi's while loop sees that a flag is set.  A notifier is like an occurrance except you can send back to your main loop once it is "woken up".  You can find examples of how to use these functions by looking in the example finder (Help->Find Examples).
I hope this helps,
Justin D.
Message 8 of 8
(4,558 Views)
