Butterworth Filter
I want to build a Butterworth filter with the formula node. what should I do?
Let's do it step by step and if you can correct me.
I saw the formula for the Butterworth is:
H(jw)=1/sqrt([1+(f/fc)^2n])
now I know that the cutoff freq. is fc=1/(2*pi*R*C) where R & C  are variable and choosen by the user (this is what the teacher asked).
So if i write in the formula node this statments:
Tau=R*C;
Fc=1/(2*pi*Tau);
FdT=abs(1/sqrt([1+(f/Fc)**2*n]));
i got error. why?
(5,425 Views)
I tried to do some changes but it seems that doesn't work properly.
Can you give a look and help me plz?
Ty
(5,414 Views)
Accepted by topic author inuyasha84
You were close.  But your little loop inside the formula should look like this.  Notice the perithesis around the 2*n.  You were only squaring.  You should raise to a power of 2*n.  I added an input for the number of poles.
for ( f=0; f<1000;f++)
  H[f]=1/sqrt(1+(f/Fc)**(2*n));
 Also, there's an Absolute Value in the Numeric palette.  Use that instead of the square and square root.
(5,404 Views)
thank you so much i was going crazy!!!
(5,400 Views)
